21 - 22 of 22 Posts
You can turn off the 'Driver Distraction' function, allowing one to enter GPS addresses while the car is moving, etc:​
Enter the diagnostic menu by holding down 'power', 'brightness' and the 'home' button together for a few seconds.​
A screen will pop up with two options. Press the lower option labeled 'Detail Information & Settings'.​
A blue screen will pop up. Then hold the 'brightness' button for a few seconds until the screen changes.​
You will see the 'Driver Distraction' option on the left.​
Select that, then turn 'off' the function.​
If you turn off the car, the function will switch back to 'on' the next time you start your car. Thus, you will need to turn off the 'driver distraction' function every time when you start up.​
There are also other interesting info and options to explore in those menus.​
Be careful though making changes though!​
21 - 22 of 22 Posts
