EDIT 10/2021
Updated with videos:
Original post:
Hey folks,
I did a coolant drain and fill on my 2010 EX-L. It is not difficult at all. If you can change your own oil, you can do this as well.
Steps
1.Make sure that the engine is cold. DO NOT open the radiator cap if the engine is hot.
2. Unscrew the radiator cap and install it lightly over the radiator, this makes sure that you don't get any debris in your radiator.
3. Now go underneath the van, place a drain pan below the radiator and remove the petcock. Don't remove the plug all the way out, just enough were the coolant starts to drain.
4. Clean the petcock and reinstall. Don't tighten it like a bolt, once it stops turning stop there. just make sure its not loose.
5. Now on to the coolant reservoir. Remove the two 10mm bolts and unscrew the overflow hose. Carefully wiggle out the reservoir with the reservoir bracket out of the van.
6. Clean the reservoir with a hose to flush out any debris.
7. Reinstall the reservoir and reservoir bracket and tighten the 10mm bolts. Don't tighten the bolt too much. If you strip the threads on the radiator, well.....you need a new radiator.
8. Now fill the radiator with coolant until it fills up. Fill the coolant reservoir between the MIN and MAX lines and screw the hose back on.
9. Before you start the van, you can squeeze the upper radiator hose if you want to to release any trapped air.
10. Turn the AC settings to HI before starting the van up. Start the van up without the radiator cap installed. Let it idle till the radiator fan kicks on 2-3 times or just wait till it reaches operating temperature. You can also give the van few revs. Top off the coolant if it gets low.
11. Before installing the radiator cap, check the coolant reservoir and top off as needed.
12. Install the radiator cap and go for a ride. Make sure the van is not overheating. Also make sure the heat is working too.
13. Drive back and let it cool down.
14. After it cools down, check the radiator and coolant reservoir and top off as needed.
15. You may have to repeat steps 14 and 15 to make sure the coolant isn't low.
And that's basically it. Just make sure to check the coolant levels a week or two after you drained the coolant. Keep in mind this method doesn't completely drain the whole system, but it gets out majority of the coolant.
Original post:
Hey folks,
Steps
