I stripped my oil pan drain bolt, and replaced with a Dorman oversized bolt. Do you think this Fumoto will fit?
7.4K views 11 replies 6 participants last post by  0dyfamily
If this were my ride, I would either helicoil it and get to the correct size and then use the correct Fumoto or just bite the bullet, chalk it up as an expensive lesson learned and replace the pan and then switch to Fumoto.
I only hand tighten the drain bolt and have never torqued it and never had any leaks either. I at times even reuse the crush washer without issues.
