lining up timing marks
22K views 5 replies 5 participants last post by  Giewont
Hey folks,
I promise that I have read every thread that I SEARCHED for at least twice on timing belt changes. 2000 ody, 116,000 miles. My water pump went. I decided to tackle this on my own after reading so much on this blessed forum. Turns out my idler bearing below the water pump pulley blew up (ball bearings everywhere). The water pump pulley was bent and immobile and my timing belt was starting to shred so I am very lucky more damage did not occur. I replaced the water pump, idler bearing, timing belt adjuster, and belt tensioner so far. I will also be changing out the other belts and thermostat.
I tried the silver pen trick but realized later that the blown bearing already put the belt out of whack. I have recompressed my tensioner about 4 times now retrying to line up those timing marks. After reading all the tips on putting the belt back on and getting the timing marks to hit at the right spot, I still can't seem to get it right. Can anyone offer some angle or method of reinstalling the belt that might be helpful. Maybe I am not using the threaded battery hold down at the right time or tightening the idler pulley in the right order. Some advice please.
thanks,
Mark
:confused:
#2 · (Edited)
Mark,
Wow – sorry to hear about that idler seizing.
As you know, if you had been able to mark that belt (i.e. if you weren’t in this unusual situation with the failure) then your life would be much easier. But it will still work out (just be careful).
Let me make a suggestion that I hope helps. The problem is figuring how much slack there should or shouldn’t be in the belt (in particular on the side that goes from the front cam sprocket, over the idler pulley, and to the crank sprocket). Perhaps try this –based on what I recall being the situation when I did my TB.
Loosen the idler pulley until you have a mid amount of play side-to-side. Then put the belt over that idler with it being snug in the sense that there is no slop. (You are trying to reduce the number of teeth between the cam and the crank, by about a tooth or so, below what it would be if you just looped the belt over the idler with the idler not having been loosened. With the idler not loosened it seems somewhere in between - not all that snug, but too difficult to pull the belt tighter to snug it up without moving the crank or something... Loosen the pulley a bit more if you need to in order to get to this snug situation.) Sorry I'm not saying that better.
You may want to pry the idler (gently) to get it centered before you fully tighten the bolt (you can judge whether or not this seems necessary). Neither the cams or the crank should move as you tighten down the pulley.
The belt on the “right side” of the system will then be nice and snug. On the tensioner side the belt will seem significantly looser than on the “right side”.
Don’t release the tensioner until you have rotated the engine around (two full rotations of the crank) to re-check the marks. If they line up, repeat just to be sure. The battery hold down should serve to keep the belt in place while you make this check. You just need to keep a bit of tension on the “left side” - really you just don't want it "floppy" at this point.
Hopefully you’re lucky and things line up. If not, try and figure out whether it means you need things more snug (on/over that idler pulley) to keep from ending up off a tooth or so. Also keep in mind the span of belt between the two cams (which should not have any slop in it).
I’ll think about this some more and see if I can come up with something else, but I think that you need to focus on the tension in the “right side” which is put on by you loosening that idler pulley and then snugging it back over and in place.
Best of luck.
P.S. I'm presuming in the process nothing has moved too much relative to something else (i.e. you didn't rotate the crank or the cams independently of each other...). As you rotate the engine during your check, feel for anything that seems like interference...
Also, continue to do research on this to make sure you get it right – trust but verify! Hopefully someone else who might have been in a similar situation will jump in here with advice.
#5 ·
I have same problem with my 2002 v6 Accord Vtec engine.The marks lined up in the peep holes in the cover before removing them, the crank was at TDC(The center mark on Harmonic balancer..there are 3 close together, and 1 further away, CCW.)When I removed the covers, and H Balancer,the Keyway is facing straight up towards the center of engine, and the cam gears have one tooth on each that is notched on the end of the tooth. This tooth is very close to the painted mark on the cam gear,but not exactly.The notches are aligned with a cast line on the back covers. Is this the proper orientation for installing the belt? The left camshaft wants to "spring" CCW about 1/4 turn from the marked position, if it is moved even slightly.It resists being put back into proper position.
This causes the marks to be off when installing the belt.I have tried several times with no success.What Am I doing wrong?Please help!
Thanks to anyone that can help!
#6 · (Edited)
