Hi,
2001 Odyssey LX with 151000 miles
My wife drove over a tree branch and it got stuck up under the passenger front just behind the front right tire. The car had to be jacked up to pull the branch out.
After the branch was pulled out the following happened:
1. D4 light started blinking
2. CEL came on
3. TCS light came on
Note: Driving in D4 has a noticeable lack of power until the car gets up to speed.
The car drives fine in R D1, D3
Today I put the car up on ramps and looked around for damage and couldn't find anything notable.
Reading out the codes I get the following (here are excerpts from the Odyssey Service manual):
P1753 (1) Blinks ON Torque converter clutch solenoid valve (see page 14-119)
(2): This code is caused by an electrical circuit problem and cannot be caused by a mechanical problem in the
transmission.
P0135 (41) Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater CircuitMalfunction ON (see page 11-128)
P0141 (65) Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater CircuitMalfunction ON (see page 11-128)
P1298 (20) Electrical Load Detector (ELD) Circuit High Voltage OFF (see page 11-155)
Any ideas what could cause all this?
Sounds like an electrical problem
I'm going to climb back under and check the electrical connectors on the O2 sensors.
Does anyone know where the Torque Converter Clutch Solenoid Vavle is located?
Also any idea where the ELD 3P connector is located?
Thanks,
Jim
2. CEL came on
transmission.
Thanks,
Jim
