This is for a 4-cyl CR-V.
I'm diagnosing P0420 code and need to diagnose oxygen sensors - upstream and downstream.
Upstream sensor is 2-3 years old, maybe 4. I will check the invoice for it's part number, if I'll find it....
Internet search shows measurements of upstream oxygen sensor in Volts and downstream - also in Volts.
According the the mighty internet, a good upstream O2 sensor should show oscillating values quickly changing from under 1V to above 0V. Volts...
A good downstream sensor will appear on the screen as a nearly straight line about about 0.5 V.
My scan tools measure upstream O2 sensor in mA, not Volts, and downstream in Volts. That's one problem...
Second - upstream O2 sensor is relatively steady on the graph (first picture) (idle or at some RPM's):
Downstream sensor shows flat line at idle:
Downstream sensor at 2000 rpms:
According to the internet search, upstream sensor is bad and downstream is bad under the load.
These results confuse me.
Does Honda measure O2 sensors differently than the rest of the world? (don't answer that).
More importantly: are these sensors good or bad?
FYI, I din't inspect the internals of any catalytic converters, yet. and I didn't add an acetone to the gas yet.
EDIT: the downstream O2 sensor is most likely original (190K miles) - I don't remember replacing it.
