21 - 40 of 2,025 Posts
With a VCM muzzler installed, would it ever be necessary to disconnect the muzzler to exercise the VCM system? Could there be certain parts like solenoids or what not that could get stuck after not operating for an extended period of time? (I have the tuner II on my 2011 ody)
This is more of a theoretical question: Why couldn’t the VCM system be designed to not decouple the valves from the camshaft. Just have the dead cylinders suck in fresh air, compress it and exhaust it out with no fuel or combustion air? This way there would be no vacuum sucking oil up the wrong way past the rings.
I use the plain VCMuzzler II. No automation. I do have to swap the resistor(s) summer/winter and am in search of a 100 Ohm one as the blue 82 Ohms is too low and the red 120 Ohms is too high in summer now after a thermostat change.
That said, I ran the Oddy with 82 Ohms to a NJ trip and back and if I stopped at gas stations or in traffic, the eco light and VCM occasionally turned ON. That keeps everything up and up and that should cover all your concerns and its cheaper than the the VCM Tuner II or SVCM the fully automatic ones which claim to never let the VCM turn on at all.
I have the VCM Tuner II installed now. Not one ECO light since [emoji106][emoji106]. My understanding is this one disables 100% which is what I was looking for. Just wondered if I should disconnect it every so often.
I am guessing that Honda does not want little engine oil to be just vented out through exhaust potentially fouling catalytic converter? I DID think about this as well. why not just shut off the fuel injector? I don't know and I am sure there is a reason they went through such trouble to enable/disable valves.
Discussion starter · #24 ·
Well at this point, I'm sure many people have had their S-VCMs and VCMTuner IIs installed for a long period of time and mileage. I doubt they disconnect theirs on occasion and if there were any issues, I'd imagine we would have heard about it by now.
owns 2006 Honda Odyssey EX
This is a great write up, thank you. It came just in time as I was thinking of getting a muzzler and wondered what the differences were. My '12 EX-L has 95k miles and I was planning on trading it in this year, but with new car prices sky rocketing to ridiculous levels, it made sense to hold on to my car a bit longer. At less than 50k miles we got the dreaded engine misfire and Honda picked up the tab to swap out the rings and plugs, but I don't want to chance it happening again while I own the car and there is no warranty. This is going to be the easy part of keeping the car a little longer. The timing belt and water pump will take a bit more work to get done. I almost forgot to ask, with the VCM disabled, I know I will get slightly worse gas mileage, but approximately how much worse?
Maybe 1 mpg. In the case of my 2015, disabling VCM made absolutely no difference to the fuel consumption at all. For some people, their fuel economy actually went up after disabling the VCM. It depends on how and where you drive.
Thanks for the answers, much appreciated. I had one more question. S-VCM or VCM Tuner II ? Both seem to work similar and require no messing with controls once installed. S-VCM is $30 cheaper, so I am leaning towards that device, unless someone tells me otherwise.
Excellent and concise info! I have an '03 EX-L and recently purchased an '06 Touring. I'm still keeping the '03 around for a while as it's been a really good car and is still useful for work. As a handyperson, I love having my tools locked up 'safe' and dry in the van . Thank you for laying it all out so I can better understand this system!!!!
Here's a thread I started a couple of years ago on VCMTUNER II and why I picked it over the S-VCM:
I felt the extra features of the VCMTUNER II were worth the extra cost compared to the S-VCM. The price difference when shipping costs were considered (within US vs. shipment to US from Canada) was less than $20 at the time.
I'm one where based on how I drive, my highway mileage actually increased. I think it's because when VCM was active, I'd only have the ECO light on for short periods of typically less than 30 seconds, and the switching back and forth from 6 and 3 cylinders was less efficient than now where 6 cylinders are active all the time. I definitely like how smooth and responsive it is with all 6 cylinders functioning all the time.
Discussion starter · #32 ·
What BertS said. Besides price, the only advantage the S-VCM has is that they will ship to California, unlike VCMTuner II.
VCMTuner II overall seems to have really good build quality and reliability. It also has a feature where it can sense if the car is idling, and it will shut itself off in those cases in order to do certain service procedures like idle relearns where the actual coolant temperature reading is needed. For the S-VCM, you'd have to remove a fuse. This is especially useful for if you get this done at a shop, as they may not be aware of you installing a VCM disable device. That'd be fine with the VCMTuner II as it can automatically handle it, but you'd have to inform them beforehand about the S-VCM and then they'll have to mess with it and take out the fuse and all that.
Reactions: BertS
Also, wouldn't just taking the fuse out and putting fuse back in while engine is hot throw CEL? Just wondering. I know putting in the S-VCM/VCM Tuner while car is not cold causes CEL so taking fuse out (does taking fuse out automatically puts it into bypass mode?) and putting it back in wouldn't be different? I don't know.
Discussion starter · #34 ·
Yes, it would be, meaning that you'd have to take it out when the car is cold.
Great post and summary. Very much appreciated. Two questions (2009 EX-L, 85K miles):
First: Is VCM related to the dreaded steering wheel "shimmy" that many Odyssey owners complain about? I recently replaced both half shafts as the shimmy was unbearable, which reduced the shimmy by 90%, but the remaining 10% is still annoying. Could the VCM be the culprit for the residual?
Second: You mention Active Noise Cancellation, and the manual cites it as well. Does it work? With the audio off? I've never been able to detect a difference.
Thanks in advance.
Discussion starter · #36 ·
VCM can cause a vibration if the active motor mounts are worn out. Did you also check the intermediate shaft? It can often go bad and cause a slight vibration. Also, did you replace with OEM axles?
The ANC is not connected to having the radio on. Completely separate.
I think this has solved a problem with my 08 Touring getting a ECL and VSA lights. Scan tool showed engine misfire on cyl. 4. Replaced the coil pack and the lights were gone. I was happy as a clam until a few days later when the lights came on again. I took the van back to the parts store, and their scanner showed the same as before, misfire on cyl. 4.
Thanks for posting this. I will swap the coil packs on # 4 and # 5 and see if the scan still shows misfire on #4.
Thanks WiiMaster. Did not consider the intermediate staft as it has no CV pieces. I did use OEM axles. The shimmy was present for about 40K miles (yeah, I know.......), so it could be the mounts. I hate the thought of taking it in just to have the dealer shotgun the problem which means a ton of money.
Discussion starter · #39 ·
It's possible you may need new spark plugs due to VCM fouling up the plug with oil.
I assume you will also muzzle your VCM? That’s perhaps the most important and significant thing you can do.
Reactions: WiiMaster
