Ok, I'm trying to replace the fuel filter on my '01 now that it has 108k on it. Yes, I know it's not replaceable but I'm anal and keep thinking if the filter was replaced then you wouldn't have to replace the pump eventually (the dealer just said you replace it when you replace the pump). Anyway, using this thread as inspiration, http://www.odyclub.com/forums/showthread.php?s=&threadid=2633 , I have the fuel lines disconnected and I'm trying to get the assembly out.
My question is it appears that the large black ring is something that screws on the tank and holds the pump assembly in place. As such, it should just spin off, correct? I've tried and tried to get it to turn and it won't budge. Am I correct, and is this black ring just threaded with normal direction threads on the tank? Any hints at removing it? I know there's supposed to be a special tool but I was thinking there must be another way to remove it.
