Hey Gang,
My Ody is doing great, but I have noticed a rattle on the drivers side. It sounds like it is coming from the column between the front driver door and the driver sliding door. But then again, at times it sounds like its the sliding door or either the drivers door.
While driving, I have tried hitting the doors and column to make it happen, but I can't. However, if I hit a bump or a series of bumps, it happens every time.
I'm thinking about taking it in to have it checked, but I don't want them to cause more rattles after they put things back together.
What do you folks think it could be? What could be loose in either door or column but still have everything work as they should?
Thanks!
Thanks!
