DIY Guide – Re-installing the lower lift-gate window trim on a 2018-2024 Honda Odyssey (part #73220-THR-A01)
(for owners who don’t want to pay a glass shop to pull the rear windshield)
What you’re fixing
The rubber lip bonded to the chrome/black strip along the bottom edge of the back glass dries out and crumbles. Honda sells the strip ( 73220-THR-A01, MSRP ≈ $45 ) and nine plastic slide-on clips ( 91512-THR-A01, ≈ $2–3 each ).
Three clips (the two ends and the center) are glued to the glass from the factory; the six “floating” clips can be replaced. The trim must slide on/off those clips; prying straight off usually kinks them.
Tools & supplies
Item | Purpose | Notes |
Heat gun (or 1 kW hair-dryer on High) | Softens the plastic clips and the new molding so they flex | Keep moving – 200 °C max |
Needle-nose pliers wrapped with 2–3 layers of masking tape | Acts as a miniature “spreader” to close clip gap | Tape prevents marring |
Plastic trim stick / old credit card | Popping off end caps; guiding molding | Metal screwdriver risks scratching paint |
Silicone spray or silicone grease | Lubes clip channels so the molding slides | WD-40 works in a pinch |
Shop towel / leather glove | Pressing hot trim flush while it cools | Protects fingers |
Optional: new clips 91512-THR-A01 | Replace any broken floaters | Buy 3–4 spares |
Removal (≈ 10 min)
- Open the lift-gate and pop off one end cap (driver or passenger) with the plastic trim stick.
- Shoot a little silicone spray along the channel.
- Slide the old molding sideways toward the opposite end. Steady, even pulls—do not pry straight out; you will snap the glued clips.
- If a clip does shatter, pry its stump off the glass with needle-nose pliers; scrape residual butyl with a plastic razor.
“Tune” the clips before re-fit
This is the step that saves you hours of frustration.
Problem: The upper tongue of each clip grabs fine, but the lower tang sits too far open after removal, so the trim’s C-channel never seats.
Fix:
- Aim the heat gun at a clip for ~8 sec (until glossy).
- Slip the taped needle-nose behind the lower tang – only insert, do NOT lever.
- Keep gentle forward pressure; when the plastic softens, the pliers walk in and pinch the gap closed ~1 mm.
- Stop heat, hold 10 sec so the clip re-hardens.
Do this on every floating clip and test with a scrap of the molding: you should feel a positive snap top and bottom.
Installation sequence
- Pre-lube the new molding’s rubber channel with a thin wipe of silicone grease.
- Start at the tuned clips (center is easiest). Bottom lip first, then rock the top edge until it clicks.
- Work outward, pushing the molding onto each clip. If resistance spikes, back off and re-lube; do not hammer.
- Once all nine clips are engaged, sight along the strip: the chrome/painted surfaces should sit parallel to the wiper arm.
- Minor waviness? Warm the spot with the heat gun, press firmly with a folded towel until cool—plastic “resets” flush.
End-caps and final check
Snap the two black end caps back on. Tug the molding left-right: it should move less than 1 mm. Run a garden hose over the strip and look for drips inside the lift-gate; none = success.
FAQ / Tips
Issue | Cause & Cure |
Can’t slide new strip more than 6″ | Too much friction. Remove strip, re-spray silicone, or skip the first clip, over-slide, then slide back (works around the curve). |
Bottom lip still won’t catch | Clip gap not closed enough. Re-heat individual clip, pinch tighter. |
One glued clip broke off | Order 91512-THR-A01, clean glass, bond with 3M Super-Strength molding tape and a dab of black RTV; let cure 4 hrs before mounting strip. |
Why not rubberized undercoat behind molding? | Water must drain; heavy undercoat traps moisture. Honda specs bare glass + clip + molding only. |
Cost & time recap
- Parts: $45 strip + ≤ $27 clips = < $75
- Tools: household heat gun + pliers
- DIY time: 45–60 min if clips pre-tuned
