there you go bargain boy
Do steps 1 - 12 on the same remote (AT TIME OF PROGRAMMING BOTH REMOTES MUST BE PRESENT SINCE THEY WILL NOW BOTH HAVE TO BE REPROGRAMMED.) The following steps 1-12 are done on a single remote step 10 is done on all remotes to be programmed up to 4 can be programmed
1) get into the car shut the doors (including trunk or tailgate) and make sure they are unlocked
2) turn on the ignition (do not turn on the engine just the ignition til the dash lights come on) (LISTEN FOR A QUIET CLICK)
3) press the lock button on remote (turn to off) (Do not remove key)
4) turn on the ignition (do not turn on the car just the ignition) (LISTEN FOR A QUIET CLICK)
5) press the lock button on remote (turn to off )
6) turn on the ignition (do not turn on the car just the ignition) (LISTEN FOR A QUIET CLICK)
7) press the lock button on remote (turn to off )
8) turn on the ignition (do not turn on the car just the ignition) (LISTEN FOR A QUIET CLICK)
9) press the lock button on the remote
the locks should cycle to indicate that programming mode was entered successfully
10) press the LOCK button on each remote you want programmed and the door locks should cycle again to confirm programming. THIS STEP NEEDS TO BE DONE FOR EACH REMOTE
11) turn off the car fully and remove key.
12) try locking/unlocking with remote to test - See more at:
2007 Honda Odyssey Keyless Remote Programming - Car Forums and Automotive Chat
http://www.automotiveforums.com/t1022690-discuss2007_honda_odyssey_keyless_remote_programming.htmlDo steps 1 - 12 on the same remote (AT TIME OF PROGRAMMING BOTH REMOTES MUST BE PRESENT SINCE THEY WILL NOW BOTH HAVE TO BE REPROGRAMMED.) The following steps 1-12 are done on a single remote step 10 is done on all remotes to be programmed up to 4 can be programmed
- See more at:
- See more at:
- See more at:
- See more at:
