The Denso alternators available on RockAuto are reman only. Unfortunately, the warranty is only 12 mos. I'm surprised to see a Denso fail so soon but there is always a failure rate for any part, even if low, for any part. Alternators will fail prematurely if they are asked to bring back a dead battery, especially when the alternator is new. So, if the battery is dead and you install a new alternator and try to charge the battery, you will damage the new alternator or shorten its life. You should always charge the battery before you start the vehicle after an alternator change.
If the battery has gone completely dead a time or two and you use jumper cables to start it and have the alternator recharge the battery it puts a huge load on it and they can wear out prematurely.
