41 - 60 of 78 Posts
Discussion starter · #41 ·
It was a lower pitched rattle sound. I could take a long screwdriver and put it on the bolt while the engine was running and feel it at the tensioner.
It is also common to have some of the heat shields rattle underneath the car so that should also be checked.
I’ll definitely check my heat shields. I installed band clamps around the ones at the converters a couple years ago. I know there are others to check. I wouldn’t think a heat shield rattle would go away in 15 seconds unless there’s some sort of thermal expansion going on.
Discussion starter · #43 ·
Sometimes it seems like it's related to the engine being cold when it's really just related to the RPM of a cold engine. This is what I found with the serpentine belt tensioner rattle. It only happened when cold, with the AC on, and in Reverse or Drive at idle. When it warmed up it went away. However, when I got more into it, I found I could make it happen any time if I was able to put it in gear and get the RPM just right at 11-1200 RPM, the same as where it idles when cold.
John:
I figured out how to upload a video to YouTube of the noise I am hearing. I hope this link works. Note that this is a cold start. The AC is off. Noise goes away after 30 seconds. Does this sound like the tensioner and belt issue you experienced? If not any guess at what it might be? Thank you very much.
Update:
I finally had the genuine Honda serpentine belt installed in hopes that it would resolve my cold start clanking/rattling noise issue. Sadly, it did not.
I did not. I had the Honda belt installed by my independent mechanic in conjunction with some other work I was having done.
Follow-up: I just had my exhaust J pipe (aka Y pipe) replaced due to a leak. I no longer hear the noise upon cold engine start. I need to get more data samples, but I’m hoping this issue is resolved. Could just be a coincidence, however.
Recently replaced a belt, and tensioner kit. After replacement, nothing but issues. Last issue presented is harmonic balancer knocking. Going to try the OEM Honda belt and see if this resolves the problem. If so, this needs to be more widely addressed by Honda. I have never had such issues with a simple job like this one. This would be the first vehicle I have worked on that has been so specific to what belt it likes.
John Clark and others, thanks for this post! I have a 2008 Odyssey Touring with 143,000 miles. My wife told me it was "making a funny noise". It sounded a little like marbles in a tin can. I suspected the AC clutch or tensioner after noticing the noise would go away when the AC compressor would turn off. After some confusion between the two types of tensioners (spring vs hydraulic - mine is hydraulic of course), I found this post and checked the belt itself. I thought it was good as it was replaced around 100k when they did the timing belt, but I did notice it had a nick in it. I figured I'd replace it either way and see if that takes care of the noise. Additionally, the belt they used was a cheap "Bando" brand, but I sprung for the $30 Continental belt at AutoZone. Also picked up the belt tool with the extension and I'm glad I did.
I also wanted to note, the Continental belt seemed so much thicker and robust than the Bando. Maybe the thinner belt stretched too much? Also, the tensioner, pulley, idler pulley, and harmonic balancer all seemed good. The noise seems to have gone away so far. We'll keep an ear out for it, though.
Just some notes for folks that want to replace the belt, I found it was difficult to get the belt back on with just the tool itself. And I'm a relatively strong, big guy. I put the extension on it with a 1/2" 19mm socket (FYI, this does not come with it, you have to have it or buy a 19mm socket), angled against the alternator wire loom and then the handle attaches to that with it's 3/8" end - push towards firewall. This gave me the extra leverage that made sliding the belt on the tensioner pulley much easier. I did everything from the top of the engine, removed the engine cover, unlocked the power steering reservoir from it's bracket and put the prop rod in the second location towards to the back of the hood to provide more room. It was a little difficult routing then new belt through the idler, AC and crank pulleys, but I got it without too much trouble.
Anyway, appreciate the info from this site, it helped save me quite a bit of time and money. (y)
Welcome to this forum; I'm glad it helped you resolve your issue. FWIW, I do not know if the new Continental belt you installed is as thick as, and as good as, the genuine Honda belt. For a little bit more money, you could have bought the Honda belt. If your noise returns, that's what I would recommend you do.
Have you muzzled your VCM? Timing belt been changed?
Discussion starter · #55 ·
Also, to note, the hydraulic tensioners require a somewhat special procedure for releasing tension. You are only supposed to apply steady pressure and allow the hydraulic piston to move slowly. If you force it hard, as you would with a spring, with a lot of leverage, you can damage the hydraulic piston assembly.
thscott, thank you. I'm not sure about the thickness vs Honda's belts, but it was noticeably thicker than that Bando belt. It also has a 3 year warranty, so it appears to be a quality part. As you said, if the noise develops again, I can order a Honda belt and try that. And nope, we have not muzzled the VCM and the timing belt was changed around 100k. One odd thing I should mention: the valve covers developed holes in them around some of the spark plugs - looked like some kind of weird corrosion. Had to buy new valve covers and the VCM was leaking badly, got that replaced as well. Both of these happened around 130,000 miles.
John Clark, gotcha, yes, slow steady pressure took care of it. There may be a dozen ways to do this, but for the way I was doing it, putting the extension on the belt tool moved the handle enough to avoid pushing into the power steering reservoir hose and provided a little more leverage. I may not have been able to get full lockout on the tensioner due to that hose being in the way.
Read up on VCM; most peope here disable the function with an inexpensive device. VCM can cause all sorts of serious engine issues. There's no reason not to disable it.
It's been about 100 years since the Tacoma Narrows Bridge Collapse due to harmonic wind loading. It has taken nearly that long to develop the physics of how it happened and develop simplified calculations to model it on a computer. That failure didn't involve multiple rotating elements strung together with a flexible band that changes direction and speed. Rotational harmonic problems are extremely difficult to solve..... by other than experience and brute force methods.
My guess is that vibration showed during the initial shakedown of the engine prototype or during early production. It had enough deleterious effect that somebody stumbled onto (or possibly knew of) a solution to change the belt thickness and therefore change the harmonics of the system. It works and Honda changes the specifications for the belt to reflect. But, doesn't tell the belt manufacturers why the belt needs to be about 1 mm thicker. I am very confidant Honda chose the cheapest and easiest solution to the problem. To confirm one would need to interview the design team, if you can find any without a gag order or contracted silence or alive still.
Thanks for sharing the experience John. Every time my back hurts I forget that experience come in handy occasionally.
Having spent my time inside the auto cos. & the oil cos., I'd say it's all random.
Hey, thought I'd post a solution I found to something that has been plaguing me for quite some time.
This is on my own 2008 Odyssey Touring, J35A7 VCM engine with hydraulic serpentine belt tensioner. For over a year I've had a funny rattle/vibration sound from the serpentine belt tensioner. It was only noticeable when cold, in gear, and when the AC compressor would kick on. In Park it wasn't as noticeable. I could go under the hood and put a long screwdriver on the tensioner bolt and feel the vibration. I don't recall exactly when it first happened but I remember the first thing I did was replace the tensioner as it had around 180K or something at that time so figured it was worn out and time for a new one. I was shocked when a new genuine Honda tensioner it didn't fix it. Since it only happened with the AC on I then figured it must be some extra vibration caused by an aging AC compressor and I wasn't going to bother with it. However, at around 203K the AC quit working.
I found a leak in the condenser and decided that with such high mileage it was time to rebuild the AC system. I replaced the AC compressor, condenser, and both expansion valves. When that was all done, the AC worked great (and still does) but that same vibration and rattle sound was still there when cold. While a visual inspection of the harnonic balancer showed no issues I decided to replace the harmonic balancer anyway since I was placing an order from Bernardi for some other parts. They are prone to failure on these engines and with the 218K that is currently on it thought maybe it wasn't lined up or somehow was causing the issue. I installed that last week. Nope. Didn't fix it.
After scouring the Internet and finding nothing at all about vibrations/rattles on the belt drive attributed to anything other than a bad tensioner I decided the only thing left was the belt itself. I'd replaced it at timing belt time at around 180K with a Bando belt but it had been making that noise prior. I don't recall what belt was on it before--probably a Dayco from Advance Auto. I've since learned Dayco belts aren't very good so I went with the Bando that time. I've installed many of them over the last couple of years and never had any issues or come backs with them. However, being at my wits end with this I decided to run to the local Honda dealer and buy a genuine Honda belt (supposedly made by Mitsuboshi.) When I brought it home and compared it to my Bando belt that still looked fairly new I was shocked. I've never compared two new (or lightly worn) belts before. I've compared a new Bando with a worn OEM and never noticed too much issue. However, below is what I found.
The Bando belt isn't that old and still has lots of life in it as is apparent by the the labeling still looking fresh. My special tool for measuring the grooves (not shown) showed it to be in great shape with very little wear on the groove side. Using a caliper I measured the thickness of both belts:
Bando: 4.38mm
Honda belt: 5.09mm
As shown above, the Bando belt is nearly 0.7mm thinner than the OEM Honda belt. That's nearly 20% thinner than the OEM belt. When you hold both at the same time there is a huge difference in the feel of the belts. The Honda belt is thick and rigid while the Bando belt felt thin and wimpy.
I installed the Honda belt and started it up. No more vibrations! I thought, well, I need to do a cold start so I waited until this morning and started it up again. Noise is gone.
Lesson learned: I've heard good things about Bando belts and have never had any issue with them. Their <$10 cost on RockAuto and Amazon makes them a good option when compared to the $53 price tag (discounted from the $64 the parts guy wanted at first) that Honda charges. However, the results speak for themselves. I bought the Bando belt on Amazon so maybe there are fake Bando belts too. All I know is a cheap belt fit nicely and never squealed but caused me much headache.
As to why the thinner belt caused the tensioner to vibrate, I'm not sure. All I can think of is it tends to slap around a bit more than the thicker, heavier belt. It does go directly from the AC compressor to the tensioner so maybe there is a weird vibration there that causes the belt to slap a bit and vibrate the tensioner. For now I'm not able to duplicate the vibration and rattle anymore when cold so I'm happy. Just thought I'd share with everyone else since I've found nothing about anything like this anywhere on the Internet.
Well, this report shook me up! Hope my 2014 odyssey J35Z8 - VCM doesn't develop the same problem. Just in case, I've bought 4 belts today,for real, from different companies, to test them in the near future. Bando, Mitsuboshi, Continental, & Gates. (I don't use Honda parts, since, if the cars are no longer quality, then how can their expensive dealer parts be quality? Thank you for reporting this.
41 - 60 of 78 Posts
