61 - 78 of 78 Posts
Well, this report shook me up! Hope my 2014 odyssey J35Z8 - VCM doesn't develop the same problem. Just in case, I've bought 4 belts today,for real, from different companies, to test them in the near future. Bando, Mitsuboshi, Continental, & Gates. (I don't use Honda parts, since, if the cars are no longer quality, then how can their expensive dealer aprts be quality? Thank you for reporting this.
You bought 4 aftermarket belts knowing from this thread that only Genuine Honda belt will work well?
I look forward to the results of your research project.
Hey, thought I'd post a solution I found to something that has been plaguing me for quite some time.
This is on my own 2008 Odyssey Touring, J35A7 VCM engine with hydraulic serpentine belt tensioner. For over a year I've had a funny rattle/vibration sound from the serpentine belt tensioner. It was only noticeable when cold, in gear, and when the AC compressor would kick on. In Park it wasn't as noticeable. I could go under the hood and put a long screwdriver on the tensioner bolt and feel the vibration. I don't recall exactly when it first happened but I remember the first thing I did was replace the tensioner as it had around 180K or something at that time so figured it was worn out and time for a new one. I was shocked when a new genuine Honda tensioner it didn't fix it. Since it only happened with the AC on I then figured it must be some extra vibration caused by an aging AC compressor and I wasn't going to bother with it. However, at around 203K the AC quit working.
I found a leak in the condenser and decided that with such high mileage it was time to rebuild the AC system. I replaced the AC compressor, condenser, and both expansion valves. When that was all done, the AC worked great (and still does) but that same vibration and rattle sound was still there when cold. While a visual inspection of the harnonic balancer showed no issues I decided to replace the harmonic balancer anyway since I was placing an order from Bernardi for some other parts. They are prone to failure on these engines and with the 218K that is currently on it thought maybe it wasn't lined up or somehow was causing the issue. I installed that last week. Nope. Didn't fix it.
After scouring the Internet and finding nothing at all about vibrations/rattles on the belt drive attributed to anything other than a bad tensioner I decided the only thing left was the belt itself. I'd replaced it at timing belt time at around 180K with a Bando belt but it had been making that noise prior. I don't recall what belt was on it before--probably a Dayco from Advance Auto. I've since learned Dayco belts aren't very good so I went with the Bando that time. I've installed many of them over the last couple of years and never had any issues or come backs with them. However, being at my wits end with this I decided to run to the local Honda dealer and buy a genuine Honda belt (supposedly made by Mitsuboshi.) When I brought it home and compared it to my Bando belt that still looked fairly new I was shocked. I've never compared two new (or lightly worn) belts before. I've compared a new Bando with a worn OEM and never noticed too much issue. However, below is what I found.
The Bando belt isn't that old and still has lots of life in it as is apparent by the the labeling still looking fresh. My special tool for measuring the grooves (not shown) showed it to be in great shape with very little wear on the groove side. Using a caliper I measured the thickness of both belts:
Bando: 4.38mm
Honda belt: 5.09mm
As shown above, the Bando belt is nearly 0.7mm thinner than the OEM Honda belt. That's nearly 20% thinner than the OEM belt. When you hold both at the same time there is a huge difference in the feel of the belts. The Honda belt is thick and rigid while the Bando belt felt thin and wimpy.
I installed the Honda belt and started it up. No more vibrations! I thought, well, I need to do a cold start so I waited until this morning and started it up again. Noise is gone.
Lesson learned: I've heard good things about Bando belts and have never had any issue with them. Their <$10 cost on RockAuto and Amazon makes them a good option when compared to the $53 price tag (discounted from the $64 the parts guy wanted at first) that Honda charges. However, the results speak for themselves. I bought the Bando belt on Amazon so maybe there are fake Bando belts too. All I know is a cheap belt fit nicely and never squealed but caused me much headache.
As to why the thinner belt caused the tensioner to vibrate, I'm not sure. All I can think of is it tends to slap around a bit more than the thicker, heavier belt. It does go directly from the AC compressor to the tensioner so maybe there is a weird vibration there that causes the belt to slap a bit and vibrate the tensioner. For now I'm not able to duplicate the vibration and rattle anymore when cold so I'm happy. Just thought I'd share with everyone else since I've found nothing about anything like this anywhere on the Internet.
My apologies for being a doubtin' thomas. i believe they solved this problem in the 2011-2017 series, but maybe not. i'm now a convert. i've now found similar problems on other car forums. kudos to john clark
i just want to thanks the author, i'm from Brazil and i have an honda City 2010 1.5L L15A engine (basically the sedan version from fit ge8), and i've went crazy for about a year with engine noises, on last weekend i've notice that the belt tensioner was vibrating, so i thought that it was the problem, and i went for google and i spawned on this post, i was using an dayco belt.. since other guy where on post said that continental belt has about same measures from the OEM, so i ordered from internet the belt from continental, few days later it arrived and i've installed it.. and voy ala... engine running like new again with no abnormal noises
Good going. FYI, John Clark is legendary here in the USA, and now perhaps in Brazil.
I just discovered this thread today (I usually only peruse the 4th gen forum). Its too bad i didnt see it earlier this year...
During the TB job on my 2012 EXL about 6 years ago the shop reportedly installed a genuine Honda serpentine belt tensioner but the repair sheet does not indicate a new belt. Fast forward to this year, I isolated a rattle noise to the tensioner, just as John noted in the original post (I assume I still had the original belt with 150k+ miles). So I naturally replaced the tensioner and installed a Gates belt but the noise persists. Now I apparently need to buy a new Honda belt.
Update: I just measured my Gates K060841 belt and it is about 4.1 mm thick! That's even thinner than the Bando belt John described.
During the TB job on my 2012 EXL about 6 years ago the shop reportedly installed a genuine Honda serpentine belt tensioner but the repair sheet does not indicate a new belt. Fast forward to this year, I isolated a rattle noise to the tensioner, as John noted in the original post. So I naturally replaced the tensioner and installed a Gates belt but the noise persists. Now I need to buy a Honda belt.
I don't know that I've actually heard of this problem also existing on the 4th gen before. Good to know.
owns 2006 Honda Odyssey EX
Follow up: I received the new serpentine belt yesterday from hondapartsnow.com. While I waited for the shipment, during my weekly parts store visit I used a manual caliper to measure a Continental belt in order to create the following list of belt thicknesses. Besides, I'm off work this week and the kids are still in school, so what better way to spend my "extra" time than at a parts store measuring belts…
Honda (Mitsuboshi): ~5.1 mm
Gates: ~4.1 mm
Continental: ~3.95 mm
*Dayco: ~3.97 mm (5/32”)
**Bando: 4.38 mm
*based on advertised measurement (Grainger)
**based on John Clark's measurement
Just wanted to add my experience here, hopefully it helps. I didn't really read this thread at first because it was discussing an older generation Odyssey and my noise was more prevalent when the engine was warm.
Anyway, I just changed my thin aftermarket belt for the thicker Honda belt earlier and no more noise and vibration. When I was buying the belt at the dealer last week I mentioned that I may have made a mistake using a aftermarket belt the parts guy nodded and said: “tensioner flopping around isn’t it?”.
Unfortunately I bought a tensioner that I don’t need, so I’ll probably post it up on here for sale once it shows up. 🤣
FltMech
. . . I just changed my thin aftermarket belt for the thicker Honda belt . . .
. . . I may have made a mistake using a aftermarket belt the parts guy nodded and said: “tensioner flopping around isn’t it?”.
I bought a tensioner that I don’t need, . . .
. . . so I’ll probably post it up on here for sale . . .
So, just to recap,
You installed an aftermarket serp/acc belt, was noisy, then bought the factory Honda belt , then all good.
But bought the tensioner just in case? . . .
Depending on miles that may be ok to install imo.
Keep that part in house imo.
Then you will never need , if in stock, Murphy's Law. :p
Yes, using some after market accessory / serp belts rattle a bit.
Best to pony up for the Honda part.
So, just to recap,
Yeah I ordered the tensioner just in case, from Amayama was $175 so not too bad. When I put the aftermarket belt on I had also installed new Honda tensioner and idler pulleys and all the hardware.
Like you said though, I may just throw it on there. The tensioner pulley bearing still seems good but there is a weird wear pattern in the finish on the pulley, I guess from the odd vibration of the belt.
61 - 78 of 78 Posts
