I tried starlight silver spray
I recently had to repair some deep scratches on my wing mirror, so I did the full job of spray filler primer/sanding till it was all smooth and primed the entire mirror. Looked very good till here. I had special ordered some starlight silver spray paint from dmbpaint.com Honda color code NH638M. This went on very well and uniform and the color looked a good match, but somewhat flat or dull in appearance. I thought the clear topcoat would do the trick, but despite several coats of clear topcoat, it just doesn't have the same shine as the factory paint. the color match is very good though, just noticebly less glossy if you look. My guess is that the original base coat was too 'rough' to give the nice glossy finish with the clar top coat. I had sanded the primer with 1500 grit before the base coat.
Can any of you guys with painting experience shed some light?
