Hello, This is my first post. Lots of good info here.
Looking through the transmission service posts it appears to be quite easy. My question is how much ATF is required to go from the lower hole to the top hole on the transmission dipstick? I don't want to be adding 1oz at a time if that space takes a quart (I just do not want to overfill).
I plan to measure how much I remove and put that much back in (and checking the fluid level prior to draining). when I checked the fluid level last night it looked low (below the lower hole) but I doubt it was at "operating temp".
Thanks,
Scott
Thanks,
Scott
