(UPDATE) We figured it out! I tightened the gas cap to make sure she tightened it enough, sure enough it went-away! Lol.😂🤣 My wife has arthritis, i told her to give it two clicks just in case even though it says one. Loose gas caps is the #1 cause of engine light coming on.
Glad to hear that it was a simple solution!
It might be a good idea to purchase a relatively low cost hand held OBDII reader. Bought one at Costco many years ago for under $35 and had used it dozens of times on many vehicles--saved many trips to the parts store. Using the reader and with the help of this forum, have saved hundreds of dollars in ferreting out weird OBDII codes on vehicles outside of the emissions system warranty.
I recently bought an inexpensive (less than $25) one from Amazon--does a bit more function/display wise, but seems to do the job. Not quite on par with the ones the mechanics/parts stores use, but should be perfectly fine to read codes, and most importantly, clear the codes once the problem has been identified and remedied.
Since your wife has arthritis, I would venture to say that the CEL light may pop up again, so the device would be great piece of mind to see that it was due to a loose gas cap. That being said, not all CELs in the future will not be due to the gas cap, so having a code reading device at home could alert you to more nefarious problems.
Great choice with the VCM Tuner II--apparently it was recently approved by the California Air Resources Board and can be used in all 50 states!
I couldn't find the recall notice on the VCM Tuner website.
