1 - 6 of 6 Posts
Achomey
Discussion starter · #1 ·
The wiring of this sensor got pulled out during my TB replacement. I don't know what this sensor is (doesn't seem like an ABS related one, but I could be wrong). The wire ferrules got pulled out cleanly, so I'm hoping I can just push them back in. However, I am not sure about the wire color position (pink, green, purple). Are there schematics for that part that anyone can share?
thanks for any help!
162308
As others have said, that is the front suspension stroke sensor. It is used as part of the headlight levelling system used on the Elite vans with HIDs.
The pictures in the diagrams aren't very helpful, but here is the pin order:
Pin 1: Purple
Pin 2: LT Green
Pin 3: Pink
I don't know which way the pin numbering is, so you'll have to take your best guess there - the 'lay' of the harness may help you in figuring that out.
-Charlie
Discussion starter · #6 ·
Hooked it all back up and it seems to be working (although not sure if an error would be thrown otherwise). Pink (top), Green (middle), Purple (bottom).
Also finished my TB change thanks to this forum and all the awesome knowledge & help. Thanks people!
1 - 6 of 6 Posts
