I know where the start interior relay / fuse is. But I want to slice into the wire after the interior fuse box & starter relay and before the neutral safety switch that then continues to the starter. So I need to find the wire coming out of the starter relay in the cabin and slice into it before it goes through the firewall to the neutral safety switch and starter.
I have a 2007 Honda Odyssey. I have attached the diagram of the kill switch. It is an ignition kill switch that when the kill switch is not on and someone turns on the car, it won't start because line between the starter relay and the neutral safety switch will not be connected and instead route the power to the horn (or in my case to a timer relay that is connected to two 300 db sirens mounted inside the door right next to the driver and passenger front seat while at the same time setting off 12 SUPER bright seizures inducing spastic flashing lights on the outside the car to get attention and a few inside the car to create more confusion at the same time of being surprised by two 300 db sirens going off INSIDE the cabin.
All I have to find is which wire is coming from the starter relay inside the cabin before it goes through the firewall to the neutral safety switch.
