Will 18x8 2018 Maxima wheels fit an 06?
4K views 6 replies 3 participants last post by  phreaktor
What do you mean by "spline"? The 14mm x1.5 pitch threaded stud is wider in diameter than any 12mm stud regardless of pitch.
Did you actually measure your Odyssey hub centers? That's the small round part that fits into the wheel center. For the longest time, Odysseys have used 64.1mm. Given all of the weird figures on the web, you might want to just get a set of digital calipers and make sure.
Your Odyssey wheel bolt circle is 5 x 120mm. Same for every Odyssey built from the 2005 model year, and onwards. I think the 2018 Maxima is a 5 x 114.3mm, which is pretty standard for a lot of Japanese cars. This would be an automatic no-go for fitment.
That Maxima wheel has an offset of +50mm, same as the Odyssey ... but they would only fit 2004 and younger Odysseys.
