2010 EX-L
A couple days ago the van started having some electrical gremlins. Interior lights flickering, what sounded like a relay clicking under the right rear interior panel, then ABS and VSA lights came on.
Shut it off. On restart it just cranked and wouldn’t start
Key out and back in and it started.
Shut it off and walked away and the daytime running lights stayed on. No key in the ignition.
Battery is a 12.7v off and 13.5v while running.
Went to check for codes at Autozone and got the following.
U0029 F-CAN MALFUNCTION (BUS-OFF)
U0155 Auto AC Sub display lost communication with gauge control module
Finally, just before pulling into the house the left rear window went down on its own and won’t go back up.
Some other info.
The interior dash lights get very dim when I turn on the headlights. Like not normal dim.
The sliding doors won’t power open.
I changed the wheel bearings a couple weeks ago. Made sure the magnets where on the pickup side. All has been well until this.
Any insight?
Thanks
Some other info.
Any insight?
Thanks
