Hello all. I've tried searching the forums but haven't found a specific answer for some of my questions. My family has had our 2018 Odyssey EX-L Navi+RES (9-speed ZF) for 15 months and just passed 37,000 miles (mostly highway miles). Took to dealer for maintenance minder code B1 (oil change and tire rotation with inspection on many other items, otherwise I'd do it myself or take to a less expensive local shop I trust.) Dealer says I need a transmission fluid change immediately. I replied: "No way. Your maintenance minder has not produced a code 3 for this maintenance item yet. Show me in your manuals or other official owner's documentation that tells me that I need to do this." He could not provide documentation, but still pressed his reason that "it's recommended at 30,000 miles." Hogwash.
There is very little information that Honda gives for regular service intervals. (The Maintenance Minder is a perfect example of "None of us is as dumb as all of us" corporate mentality of taking something completely logical--a recommended maintenance interval table by mileage--and ramming a stupid solution down customer's throats. I've been doing the regular portions of my own vehicle maintenance for over 25 years, but Honda has decided in their infinite wisdom that regular consumers are too stupid to understand their own vehicles. Please Honda, just give us recommended maintenance schedules like every other sane car maker does! Meh; I digress.)
The owner's manual provides this information as a footnote to the "code 3"--change transmission fluid--in the owner's manual: "Driving in mountainous areas at very low vehicle speeds or trailer towing results in higher transmissiontemperatures. This requires transmission fluid changes more frequently than recommended by theMaintenance Minder. If you regularly drive your vehicle under these conditions, have the transmission fluidchanged at 60,000 miles (100,000 km) or 3 years, thereafter every 30,000 miles (50,000 km) or 2 years." However, there is no explanation of how often the regular interval should be.
The closest equivalent I can find is for the 2016+ Pilot with 9-speed ZF transmission, which several Honda dealers and piloteers.org recommend first change at 60,000 and then every 30,000 thereafter.
1. Can anyone provide the actual manufacturer-recommended replacement interval for the 9-speed transmission oil?
2. Someone provided links to Honda TechInfo pages on how to replace transmission oil and perform a fluid level check. However, they are behind a paywall. I saw some typed-out instructions for the Pilot 9-speed transmission (can't find link at this moment) that was some ridiculously complicated procedure requiring lifting the vehicle up on a level surface (such as with a four-point lift at a dealer's shop), loosening the fluid check-level bolt, hooking up a Honda diagnostic computer, waiting for the oil to reach a certain temperature, entering a disable code for the VSA, and then cycling through 1-4th gears and having someone else underneath the vehicle to verify whether any oil leaks out of the level-check hole. In short: can anyone confirm this for the 2018 Odyssey, or otherwise provide transcribed instructions on how to properly check the transmission fluid level.
3. Lastly, which oil is required? The Honda owners website says: "Use genuine Honda Automatic Transmission Fluid (Type 3). NOTE: Using the wrong type of fluid will damage the transmission." yet the PDF versions of the owner's manual says to use Honda ATF 3.1 or above and 3.3 quarts is required. And: are new fill plugs required with EVERY change? I can see that ebay lists Honda ATF 3.1 anywhere between about $27-53 per quart (also the same as online Honda parts websites). ZF LifeGuard 9, the manufacturer's equivalent, appears to only be sold in Europe and also at the same extortionistic prices. I can't find any other 3rd-party equivalent. I did find a fairly reasonable Acura kit at ebay with 4 qts of Honda ATF 3.1 and two drain plug bolts for $75 (sorry, I can't paste a link).
4. Any other thoughts that experienced odyclub members would like to provide?
Thanks.
Thanks.
