I have a burning question. Has anyone switched to Amsoil ATF. I live Amsoil products they never disappoint. But I haven't been able to find anywhere if it be put in instead of the Honda type 2.0 for the 10spd transmission.
There can be but most times, it’s often money related.There must be a reason Honda makes 3 different formulas vs one fluid fits all!
I did a break in drain and fill on a '23 using amsoil (red cap/multi vehicle IIRC) around 6-8k miles ago. Zero issues. I too am an amsoil fan.I have a burning question. Has anyone switched to Amsoil ATF. I live Amsoil products they never disappoint. But I haven't been able to find anywhere if it be put in instead of the Honda type 2.0 for the 10spd transmission.
I had similar experiences with my Altima CVT and switching it to Amsoil CVT fluid fixed it and made it smoother than it was ever before. So yea with that experience I think i would do the switch even though it may not fix the issue but im confident enough that it won't break it.@moonboy66
The reason I have decided to switch to Amsoil ATF for my odyssey is that it has already started hard shifting and stuttering at only 95k using the Honda ATF drained and filled at 40k then 80k. So yea OEM fluids sucks IMO."
This is not the time to be changing fluids if you already are having problems. Changing into another fluid will not improve anything, but worsen the problems. I do not think anyone here on this ODY Forum would agree with what you are attempting to "fix". If I was still working as a mechanic, I would tell you should not change the fluid, however possibly do a diagnostic check for possible reported problems, and see if you have all current software upgrades to help your ODY 10-speed transmission. If your transmission is doing this consistently, they should be able to find the problem, but not always. I believe Amsoil would tell you the same thing. If the problem exist now, changing the fluid will not improve your transmission.
Wow great to hear that!I did a break in drain and fill on a '23 using amsoil (red cap/multi vehicle IIRC) around 6-8k miles ago. Zero issues. I too am an amsoil fan.
Send an email to Amsoil & ask them. They will tell you. I use it in my 2011 Ody and cvt fluid & signature oil in my CRV.I have a burning question. Has anyone switched to Amsoil ATF. I live Amsoil products they never disappoint. But I haven't been able to find anywhere if it be put in instead of the Honda type 2.0 for the 10spd transmission.
What if you used the cheapest or the most expensive lubricant you could find and it "didn't dissapoint". Because your engine/transmission is still working does not prove the lubricant is OK. Can we simply use what's called out in the owners manual-- and link to the specs called out there to what's on the container of whatever you buy. Lets stop this endless go nowhere discussion.I have a burning question. Has anyone switched to Amsoil ATF. I live Amsoil products they never disappoint. But I haven't been able to find anywhere if it be put in instead of the Honda type 2.0 for the 10spd transmission.
Huh? Did you read all the replies to the first post?What if you used the cheapest or the most expensive lubricant you could find and it "didn't dissapoint". Because your engine/transmission is still working does not prove the lubricant is OK. Can we simply use what's called out in the owners manual-- and link to the specs called out there to what's on the container of whatever you buy. Lets stop this endless go nowhere discussion.
I am answering the man's question. IF his proposed Lub links to the specs per the lub called out in the owners manual then you can use it. If it does not then you cannot use it. That was what he asked. The dealership frankly does not know what lub you used -- Honda or something else. Actually they don't care. They get paid to fix the Trans under warranty as well as out of warranty.Huh? Did you read all the replies to the first post?
1.). The specs in the owner's manual are recommendations, not requirements. They cannot legally require you to use something without providing said something. Since they aren't going to do that for free, they cannot word it as required.I am answering the man's question. IF his proposed Lub links to the specs per the lub called out in the owners manual then you can use it. If it does not then you cannot use it. That was what he asked. The dealership frankly does not know what lub you used -- Honda or something else. Actually they don't care. They get paid to fix the Trans under warranty as well as out of warranty.
Thanks for coming back with updates. Just to confirm, you are using the red cap Multi-Vehicle ATF?Just wanted to update this post after 10+k miles with Amsoil transmission fluid, the van is running bettery smooth than ever. Zero issues. 100% recommended
Yes, the red cap bottle mutli-vehicleThanks for coming back with updates. Just to confirm, you are using the red cap Multi-Vehicle ATF?
PXMA (10 speed) transmission Amsoil recommended fluid is indeed red cap fluid.Thanks for coming back with updates. Just to confirm, you are using the red cap Multi-Vehicle ATF?
Strange, Type 2 for the 10-speed is listed in both Amsoil ATF compatibility lists:PXMA (10 speed) transmission Amsoil recommended fluid is indeed red cap fluid
Use AMSOIL Signature Series Multi-Vehicle Synthetic ATF in transmissions, hydraulics, power steering systems and other applications that require any of the following specifications: Allison C-4, TES-389; BMW 7045E, 8072B, LA 2634, LT 71141; Chrysler ATF+4*, MOPAR* ASRC, 68089195AA, 68049954AA; Ford MERCON*, MERCON* V, ESP-M2C166-H, FNR5, M2C924-A, XL-12; GM DEXRON* II, DEXRON* III, AutoTrak II; Honda/Acura ATF-Z1; Honda 2.0
Both are good ATF's, just that Multi-Vehicle has a slightly higher viscosity than Fuel-Efficient.Use AMSOIL Signature Series Fuel-Efficient Synthetic ATF in transmissions and other applications that require any of the following specifications: Aisin-Warner AW-1; BMW 83 22 0 142 516, 83 22 2 152 426; Chrysler MOPAR* 68157995AA, SP-IV, 68218925AB; DSIH 6p805; Ford MERCON* LV, SP, ULV; GM DEXRON* HP, DEXRON* VI, ULV; Honda/Acura DW-1,* Type 3.0; Honda 2.0
