For you guys doing DIY coolers, some interesting data I found on this webpage:
Electronic Transmission
Although it deals with Chrysler transmissions, it gives some insight as to what is considered normal operating temperature for ATF from the perspective of the computers that control the powertrain (PCM's) and transmissions (TCM's). Of note:
Chrysler's 45RFE uses several "shift schedules" that are based on ATF oil temperature........Once the ATF is above 40 degrees {my note: this is 40-deg Fahrenheit}, the TCM goes to the "warm" schedule, which allows normal upshifts, kickdowns and coastdowns - but still not torque converter lockup. When the ATF reaches 80 degrees F, the TCM changes to the "hot/normal" mode and begins to engage the torque converter when vehicle speed is above about 22 mph.
I was unable to find ATF temp sensor ranges for the Honda Odyssey ATF temp sensor using the Helm manual, but I still believe this article explains why one of our members had perfectly normal operation with his DIY ATF cooler setup even with an ATF dipstick that was simply warm to the touch. Shortly afterward he did install a 160F-180F thermostat to raise the operating temp to assure proper function during all seasons.
I'm also in agreement with that group that believes something warmer, like 160-deg F or warmer, is needed for optimum operation. The article notes that if you don't get to 40-deg F, you lose a lot of auto transmission functionality...in short, a thermostat is absolutely necessary if you have a robust DIY ATF cooler downstream from the OEM-radiator-mounted cooler and you drive in places where it can get really cold.
Regards, OF
Regards, OF
