Can an exhaust leak cause P1457?
6.8K views 18 replies 7 participants last post by  OdyinNH
As many of you know, I've recently installed a manual transmission and 3.2S motor into a new-to-me 2000 Odyssey LX. Last night, I took the old, badly rusted cat out and installed a test pipe (with O2 bung) in it's place. I drove it to work for the first time today and it threw a P1457 code about 5 miles into the 9 mile drive. Long story short, I've been driving this thing further and further every day. This morning was the furthest I've driven it since getting it running, but also the first time I've really driven it at all after last night's exhaust work. I haven't had any codes other than those at the very first startup that I've already fixed.
Can an exhaust leak or a test pipe cause a P1457? I don't know the history of the van, so I don't know if this was a problem before the engine swap or if it's a new problem. I have been searching and am going to eventually fix the exhaust anyway, I just wanted to pick your brains on the subject before I start replacing things.
Thanks guys.
#4 ·
gas cap I think is code 1456 isn't it?
1457 is the evap side and 1456 is tank side IIRC
i found on newish Hondas, 1457 is a result of rust buildup that pushes the seal away from the purge control solenoid doohickey... I've seen a bunch of different names for it, but I know on my 01 civic it was located on the pass side of the charcoal canister next to the tank. i wish I had taken pics to show what happens to make it fail. electrically it tested fine and moved well, but the bubbling rust created a leak around the seal. I was going to clean one up and try it to see if my theory about the method of failure is correct.
#6 ·
That's correct...so probably not the gas cap. Just have to find the leak. I'd suspect the purge valve, or hose to/from, since the vehicle didn't have the problem prior to the engine swap.
#7 ·
A P1457 is most definitely an EVAP related code. I'm sure P1457 is a 2-drive cycle code so it may not turn on the check engine light the first time it sees the problem. It will likely need to see it twice in a row before setting the code. It doesn't mean the problem isn't there. Make sure the purge valve isn't leaking.
#11 · (Edited)
I don't know the history of the van. When I bought it, it wasn't running due to a blown engine. I filled the tank at lunch yesterday and cleared the code right there at the pump. I then drove it back to work, then home after work, then to my buddy's place to jump start his car, then home again, then back to work this morning. It still hasn't thrown the code. I didn't say the problem wasn't there, I said the CEL didn't come back on due to the tank being full.
Do you smell gas at the filler neck?
If so check the gas return line ~1/2 way down the filler neck for a break.
Fixed mine!
GL
I don't smell gas at all.
#14 ·
The evap test can take a couple of days to finish. The fuel level usually has to be between 15-85% so if the tank is full it won't run the test. You can use your scan tool to check readiness monitors. If the EVAP says incomplete then it hasn't even tested it yet. Then, when it does test you'll have to get two failed tests in order to get a check engine light.
#15 ·
I replaced that valve mentioned on a 99 Accord and my 00 Ody for this code. Both within a year and the code seemed to happen more towards the half full mark. The valve is attached to the canister under the car with 2 screws that like to rust in place. Remove valve and cover one side with your hand and blow into the other side, if air comes out in the middle of the unit (2 or 3 pieces held together with metal) then it's toast. Not worth trying to get it to seal for how cheap they are to buy. Here's a thread about it.
http://www.odyclub.com/forums/24-1999-2004-odyssey/293521-p1457-my-2001-how-long-can-i-ignore.html
#18 ·
I found the purge solenoid to be leaking so I replaced it. P1457 is gone, but after two days with no CEL, P1456 popped up this morning as I pulled into work. From what I've read, it looks like this one could be a headache to track down.
