There is a gap, when viewed vertically, (varies when the outside temp does) between the top of that quarter panel (plastic) and the metal panel above. What I mean by gap is that the lower panel sort of bulges out at that joint. I can push in back in, but of course it doesn't stay. It almost appears that there should be some kind of pin coming down from the metal panel above or a pin going up from the plastic panel below to hold the outside surfaces even.
Right now, water or salt etc, can run down the upper panel and enter at the top of the lower plastic panel and then run down the inside of it. (No, I don't want to put duct tape over it.)
I was thinking of prying out the top of that plastic panel a little more (it will come out far enough to see the inside edge of it) and somehow putting something on it so that it would somehow catch on the inside of the upper metal panel when I push it in and keep it there. Perhaps something like a pushbutton type thing that will pop up once I push that lower panel back in.
I'm sure there is a fairly easy way to keep the top of that lower panel from sticking out from the upper metal panel, but I haven't thought of a way to do it.
Any solutions that are low cost?
Thanks,
Buffalo4
Thanks,
Buffalo4
