Status
Not open for further replies.
101 - 120 of 241 Posts
After October 2013, the urvi link still works, but the techinfo link does not.
You are correct. Honda appears to have changed the techinfo links recently for various newly released publications (TSBs, service news, tech line summary, etc.). The older links still work though for older stuff.
I have provided dvpatel with the new techinfo links and he will update the thread for November 2013 and December 2013.
Save
January 2014:
No articles published
Save
February 2014:
A14020B
Electronic Service Manual Fix: LaneWatch Camera Aiming, 2014 Civic
http://www.urvi.net/forumfiles/SN/A14020B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14020B/enu/A14020B.PDF
A14020C
Intermittent SRS DTC 11-1x to 11-9x, 11-Ax, 11-Bx, and B1001-x to B1002-x
EDITOR’S NOTE: This article replaces “Intermittent SRS DTC 11-1x to 11-9x, 11-Ax, and 11-Bx,” issued in January 2004.
http://www.urvi.net/forumfiles/SN/A14020C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14020C/enu/A14020C.PDF
A14020E
Turn Signal Sometimes Won’t Cancel
http://www.urvi.net/forumfiles/SN/A14020E.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14020E/enu/A14020E.PDF
A14020F
Use ServiceExpress if ISIS Isn’t Available
EDITOR’S NOTE: This article replaces “ServiceExpress: Your Trusty Backup if ISIS Goes Down,” issued in September 2008.
http://www.urvi.net/forumfiles/SN/A14020F.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14020F/enu/A14020F.PDF
Save
Save
April 2014:
A14040B
Fog Light Is Cloudy or Faded? Check the Bulb
http://www.urvi.net/forumfiles/SN/A14040B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14040B/enu/A14040B.PDF
A14040C
Apple iPod Stops Playing and iMID Flashes “USB Error” When Switching Audio Sources
http://www.urvi.net/forumfiles/SN/A14040C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14040C/enu/A14040C.PDF
A14040D
Removing and Reinstalling the Steering Column Covers
http://www.urvi.net/forumfiles/SN/A14040D.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14040D/enu/A14040D.PDF
A14040E
Remote Control Engine Starter Won’t Register; Front Passenger’s Power Seat Won’t Work
http://www.urvi.net/forumfiles/SN/A14040E.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14040E/enu/A14040E.PDF
A14040F
Power Windows and Moonroof Won’t Automatically Open with Keyless Remote or Door Key
EDITOR’S NOTE: This article replaces “Power Windows, Moonroof Won’t Work with Key or Keyless Remote,” posted in July 2013.
http://www.urvi.net/forumfiles/SN/A14040F.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14040F/enu/A14040F.PDF
Save
May 2014:
Save
Save
July 2014:
A14070B
Accessory Hood Air Deflector Adhesive-Backed Brackets Come Loose, Vibrate While Driving
http://www.urvi.net/forumfiles/SN/A14070B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14070B/enu/A14070B.PDF
A14070C
Thump or Pop From Right Front When Going Slowly Over Bumps
Currently Applies To: 2011−14 Odyssey
http://www.urvi.net/forumfiles/SN/A14070C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14070C/enu/A14070C.PDF
A14070D
Latch Plate Facing the Wrong Way? Don’t Replace the Seat Belt!
http://www.urvi.net/forumfiles/SN/A14070D.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14070D/enu/A14070D.PDF
A14070E
Electronic Service Manual Fix: LaneWatch Camera Aiming, 2015 Fit
http://www.urvi.net/forumfiles/SN/A14070E.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14070E/enu/A14070E.PDF
A14070F
Engine Oil Leak From Main Bearing Cap Side Bolts
Currently Applies To: 2008-14 Odyssey
http://www.urvi.net/forumfiles/SN/A14070F.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14070F/enu/A14070F.PDF
Save
August 2014:
A12110C
Oil Leak From Flywheel End After Short Block Replacement
EDITOR’S NOTE: This article revises the one posted in November 2012. Changes are highlighted in yellow.
http://www.urvi.net/forumfiles/SN/A12110C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A12110C/enu/A12110C.PDF
A13060B
Replacement LaneWatch Camera Won’t Aim? Read This
EDITOR’S NOTE: This article revises the one posted in December 2013. Changes are highlighted in yellow.
http://www.urvi.net/forumfiles/SN/A13060B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A13060B/enu/A13060B.PDF
A14080C
Front Passenger’s Weight Sensor Unit Won’t Initialize
Currently Applies To: 2014 Odyssey
http://www.urvi.net/forumfiles/SN/A14080C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14080C/enu/A14080C.PDF
A14080D
Understanding TPMS Calibration
EDITOR’S NOTE: This article replaces “Get to Know the New TPMS” posted in October 2012.
http://www.urvi.net/forumfiles/SN/A14080D.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14080D/enu/A14080D.PDF
Save
Save
October 2014:
A07040G
Engine Stalls in Reverse or Drive After Transmission Repair
EDITOR’S NOTE: This article revises the one posted in April 2007. Changes are highlighted in yellow.
http://www.urvi.net/forumfiles/SN/A07040G.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A07040G/enu/A07040G.PDF
A10120K
Hatch Glass Won’t Open? Check the Rear Window Wiper Stop Switch
EDITOR’S NOTE: This article revises the one posted in December 2010. Changes are highlighted in yellow.
http://www.urvi.net/forumfiles/SN/A10120K.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A10120K/enu/A10120K.PDF
A11110N
Power Sliding Door Won’t Open with VSA Indicator On
EDITOR’S NOTE: This article revises the one posted in November 2011. Changes are highlighted in yellow.
Currently Applies To: 2005-15 Odyssey EX, EX-L, and Touring
http://www.urvi.net/forumfiles/SN/A11110N.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A11110N/enu/A11110N.PDF
A14100B
TPMS Indicator On or Low Tire Pressure Indicator Flashing on 7-Year-or-Older Vehicle? Check Tire Pressure Sensor Batteries
Currently Applies To: 2005−15 Odyssey
http://www.urvi.net/forumfiles/SN/A14100B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14100B/enu/A14100B.PDF
A14100C
Keyless Access Won't Work with Front Door Handles and ENGINE START/STOP or POWER Button
http://www.urvi.net/forumfiles/SN/A14100C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14100C/enu/A14100C.PDF
A14100D
Aftermarket Replacement Windshield May Cause Advanced Safety and Driver Assist Systems to Work Abnormally
Currently Applies To: 2014-15 Odyssey EX-L, Touring
http://www.urvi.net/forumfiles/SN/A14100D.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14100D/enu/A14100D.PDF
A14100E
Cargo Area Wet? XM Radio Problems?
http://www.urvi.net/forumfiles/SN/A14100E.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14100E/enu/A14100E.PDF
A14100F
Center Rear Seat Belt Buckle Installation Is OK
EDITOR’S NOTE: This article replaces “Mixed-Up Over Rear Seat Belts?” issued in April 1995.
http://www.urvi.net/forumfiles/SN/A14100F.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14100F/enu/A14100F.PDF
Save
November 2014:
Save
December 2014:
A13030A
Wrong SRS Replacement Parts Can Cause SRS DTCs 41-xx thru 46-xx
EDITOR’S NOTE: This article revises the one posted in March 2013. Changes are highlighted in yellow.
http://www.urvi.net/forumfiles/SN/A13030A.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A13030A/enu/A13030A.PDF
A14020F
Use ServiceExpress if SIS Isn’t Available
EDITOR’S NOTE: This article revises “Use ServiceExpress if ISIS Isn’t Available,” posted in February 2014. Changes are highlighted in yellow.
A14120B
Indirect TPMS Calibration Comparison Logic and Special Calibration
http://www.urvi.net/forumfiles/SN/A14120B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14120B/enu/A14120B.PDF
A14120D
Ground Distribution Schematics Added to Next Generation EWDs
http://www.urvi.net/forumfiles/SN/A14120D.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A14120D/enu/A14120D.PDF
Save
Save
February 2015:
A15020B
Left-Foot Braking and the Brake Override System
EDITOR’S NOTE: This article replaces “Loss of Power While Driving? Could Be the Brake Override System,” posted in September 2011.
Currently Applies To: 2011-15 Odyssey
http://www.urvi.net/forumfiles/SN/A15020B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15020B/enu/A15020B.PDF
A15020C
Current EWD Column to Be Switched Off
http://www.urvi.net/forumfiles/SN/A15020C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A05020C/enu/A15020C.PDF
A15020D
No HDS Communication and Multiple Gauge Indicators On after Remote Start Installation
http://www.urvi.net/forumfiles/SN/A15020D.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15020D/enu/A15020D.PDF
Save
March 2015:
A13070F
Driver’s Seat Lowers by Itself? Try This Simple Test
EDITOR’S NOTE: This article revises the one posted in July 2013. Changes are highlighted in yellow.
Currently Applies To: 2005-10 Odyssey
http://www.urvi.net/forumfiles/SN/A13070F.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A13070F/enu/A13070F.PDF
A15030B
Transferring a Junction Board During IMA Battery Module Replacement
http://www.urvi.net/forumfiles/SN/A15030B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15030B/enu/A15030B.PDF
A15030D
Resetting the Engine Oil Life Display? Don’t Disconnect and Reconnect the 12-Volt Battery Beforehand!
EDITOR’S NOTE: This article replaces “Resetting Engine Oil Life? Don’t Touch the Battery Beforehand!” posted in June 2009.
http://www.urvi.net/forumfiles/SN/A15030D.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15030D/enu/A15030D.PDF
Save
Save
May 2015:
A14100F
EDITOR’S NOTE: This article revises the one posted in October 2014. Changes are highlighted in yellow.
A15050B
Soft Set or Bad Connection at C505 Can Cause Various Electrical Problems
EDITOR’S NOTE: This article replaces “No DVD Picture, No Compass Calibration, Security Alarm Goes Off,” posted in August 2013.
http://www.urvi.net/forumfiles/SN/A15050B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15050B/enu/A15050B.PDF
A15050C
New Features Added to Tech Line Create New Case Page
http://www.urvi.net/forumfiles/SN/A15050C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15050C/enu/A15050C.PDF
Save
June 2015:
A08010I
IMA DTCs U0110 and U1205 Set with Fuse No. 61 Blown
EDITOR’S NOTE: This article revises the one posted in January 2008. Changes are highlighted in yellow.
http://www.urvi.net/forumfiles/SN/A08010I.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A08010I/enu/A08010I.PDF
A14120B
EDITOR’S NOTE: This article revises the one posted in December 2014. Changes are highlighted in yellow.
A15060C
Condensation in Semi-Sealed Headlights is Normal
http://www.urvi.net/forumfiles/SN/A15060C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15060C/enu/A15060C.PDF
A15060D
Removing the Protective Covering from a Leather-Wrapped Steering Wheel
http://www.urvi.net/forumfiles/SN/A15060D.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15060D/enu/A15060D.PDF
A15060E
Automatic Transmission Shifts into Park by Itself? Understanding Auto Park Mode
http://www.urvi.net/forumfiles/SN/A15060E.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15060E/enu/A15060E.PDF
A15060F
New ATF and Fluid Naming Convention
http://www.urvi.net/forumfiles/SN/A15060F.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15060F/enu/A15060F.PDF
A15060G
CVT Grinds or Whines or Won’t Move in Any Gear
EDITOR’S NOTE: This article replaces “CVT Grinds or Won’t Move in Any Gear,” posted in May 2006.
http://www.urvi.net/forumfiles/SN/A15060G.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15060G/enu/A15060G.PDF
Save
July 2015:
A15070B
Don’t Use Leak Check Dye in These Vehicles!
http://www.urvi.net/forumfiles/SN/A15070B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15070B/enu/A15070B.PDF
A15070C
HFL Microphone Concern? Don’t Replace the Front Individual Map Light Assembly
http://www.urvi.net/forumfiles/SN/A15070C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15070C/enu/A15070C.PDF
A15070D
Can’t Send HDS Files to Tech Line? Check Out This Work-Around
EDITOR’S NOTE: This article replaces the one posted in August 2011.
http://www.urvi.net/forumfiles/SN/A15070D.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15070D/enu/A15070D.PDF
A15070F
In a Pinch, OK to Use ATF Type 3.0 in a 9-Speed Automatic Transmission
EDITOR’S NOTE: This article revises the Version 1 article posted earlier in July 2015. Changes are highlighted in yellow.
http://www.urvi.net/forumfiles/SN/A15070F.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/AH/A15070F/enu/A15070F.PDF
Save
Status
You have insufficient privileges to reply here.
