Laminx Fog Light Film
979 views 5 replies 4 participants last post by  redleader74
Just recently bought Laminx yellow fog light film off Amazon. Adheres easily and is cut to the shape/size of the lens (and no need to remove the house/bezels/etc. to do it. Although, when lit, the light is a very light yellow and not a deep dark yellow. Here are some photos.
#3 ·
I didn't look into changing the bulbs as I thought the foglights had built in LED's (similar to the headlights) where it's all part of the housing. If the LED's are changeable then I might consider that in the future, though, from Youtube vids it looks like you have to remove the entire bumper to access and remove the fog/turn signal housing.
#4 ·
I like it.
Did the same for the OEM fogs on my 2003 Acura TL3.2 Type S.
#6 ·
Sorry, I didn't see your reply. I looked into removing the trim/bezel for the fogs, thinking that I'd need to do so in order to properly adhere the film to the edges of the lights, but you have to actually remove everythign including the entire front bumper. However, turns out there is enough of a gamp between the surface of the fog light lens and the bezel that you can slide the film in and position it accordingly. You have to use some soapy water and spray it onto the film or the glass lens so you can slide it around to position.
