21 - 35 of 35 Posts
I am just about to start removing the transmission from my 2000 Ody by following your excellent instructions. In your original write up you mentioned that you had not removed the intermediate drive shaft, just slid the transmission off the shaft. You were concerned that it may present a problem when it came to re-installing the transmission. You didn't mention it in your installation post, did it present a problem or had you removed it before hand?
Thanks Rick
Checking the cooler flow is a most critical part of this exercise. The restriction of the cooler is a "chicken and egg" situation. Did the transmission fail because the cooler was plugged or was the cooler plugged with junk cast off when the transmission failed? Whichever is true, the lines MUST be cleared before the new transmission is installed. I remember hearing about a guy who rebuilt his transmission, installed it and had it fail just a few miles down the road because he failed to flush the lines, which were plugged. Good luck to you who are brave enough to take on this daunting task, Jerry O.
Should have read further down in your post. I couldn't figure out why the tranny wouldn't come out, then read about torque converter to flex plate bolts. I'm going to recommend to anyone who is thinking of doing this, don't. I found several shops that will do the swap for $500 if you provide transmission. I wish I would have went that route.
I know it sounds crazy, but the trans can be changed from the top. I went to look at a Craigslist with a new trans and wiring issues and the owner explained that he had to do the swap in the parking lot with minimal tools. He put it on jack stands, and used an engine crane, rented, and changed it from the top. He had to remove the ABS unit and pry and cuss a lot, but he got it done. My deal fell through and I bought one with the trans removed and the crossmember and underpinnings in place. Rather than pull everything out, I went for the top. It took my son and I most of a Sat to get it in, but we made it work. It isn't easy, but it can be done.
One other thing I ended up doing differently, and don't know effect yet. I removed the bolt at the steering connector and left steering components attached to subframe. Will let you know if this caused any problems when I get everything back together.
Thanks jpgandee. Your instructions were helpful. I just did my swap with your detailed instructions. I didn’t have an overhead bar to hoist the engine to prevent it from dropping but I used two jacks instead to hold the engine and transmission from bottom. I was afraid the oil pan or bell housing would fracture in half when I switched to one jack to bring in/out the subframe but it survived. The jack point on oil pan for me was right above the exhaust pipe (removed). Overall it was smooth sailing, except for stripped out thread on one bolt hole where it goes to the right side of the front engine mount bracket. I just used a longer bolt to chase out the threads. Thanks again for your help.
You guys are amazing and inventive. These trannies are not easy to remove or install, compared to cars and trucks form the 1970's.
Did you have to remove the ABS unit ? what else did you remove to install from the top?
Loved Reading this. Is the OP still here on this forum? How did it all end ? Not clear if you had lift or garage to do it in?
I have two old same generation ODYS and eventually may want to replace the transmission. Very handy. Experienced with problem solving and tools. But negotiating heavy weight, safely. I don't know.
21 - 35 of 35 Posts
