With 15400-PLM-A01 no longer available, what is your favorite oil filter? I have heard a lot of positive things about FRAM XG7317 Ultra Synthetic. Amazon sells them for $7. Is there any other oil filter on the market than offers a better value?
I made a comment about their whack ranking of flow rates and how that matters less. But the filtration results are undeniable and (so far) purolator boss or endurance definitely win. If people are geeking out enough to talk about oil filters, they are likely changing way too early, and may as well just get top filtration vs capacity - so seems like FRAM gets the win - but fails at marketing/doesn't want to get sued so "99+" is good enough. I do wish "brand rankings" would hype less and just like....test 3 filters bought from different locations/wal-marts. for all the work they did, sample size 1 is weak. they could just blend same filter oils for testing and it wouldn't be much additional cost - though I do appreciate the time/effort they spend on each filter test.Same for flow restriction. If they all allow acceptable lube flow, from first to last place, through the end of an OCI, then all of those filters are good enough.
If I look at it that way, then for me the winner would be the Fram Endurance.
You are already putting the car on stands to remove the oil. With the tire off you can actually sit inside the wheelwell when doing the filter. It's well worth the extra step, and as a bonus you can check your break pad wear!Why take off the tire? Anyway I use a disposable cup to remove the filter. Never makes a mess.
Amen!One thing I miss about my truck - I could get under it and change its oil without touching the jack!
I change oil on ramps - I think it's a lot easier than jackstands.You are already putting the car on stands to remove the oil. With the tire off you can actually sit inside the wheelwell when doing the filter. It's well worth the extra step, and as a bonus you can check your break pad wear!
Who da f is putting the van on jackstands just to change the oil? Bruh...You are already putting the car on stands to remove the oil. With the tire off you can actually sit inside the wheelwell when doing the filter. It's well worth the extra step, and as a bonus you can check your break pad wear!
I don't own ramps.I change oil on ramps - I think it's a lot easier than jackstands.
get ya some!I don't own ramps.
I just got a set of Race Ramps for our trio of family Civics. The ones I just got have a 1,500-lb. rating (each ramp), but it appears the company did more testing and uprated the same model to 2,500-lbs. apiece.I change oil on ramps
I do.Who da f is putting the van on jackstands just to change the oil? Bruh...
Easy there, Ted Bundy. Buy ramps.I do.
Mine have a weight rating of like 20,000lbs. I also made them myself with 2x10"s. 😆I just got a set of Race Ramps for our trio of family Civics. The ones I just got have a 1,500-lb. rating (each ramp), but it appears the company did more testing and uprated the same model to 2,500-lbs. apiece.
I'm still going to only use them for the "less weighty" vehicles like our sedans, and stick to the Rhino Ramps for our Odyssey.
Before anybody says "You paid over $600 for these??!!" ... I didn't. Local dirt track racer cleaning out his garage. I had zero idea they had such a high retail price, and he sold them to me for a "I need space in my shop" price ....
... like about the cost of a tank of 87 octane gas in my Odyssey.
Just really grateful for my good fortune of late with Facebook Marketplace, as in level of gratefulness that makes you think "Man, I should be on my knees praying thanks for these latest helpful purchases."
I bought a set of metal ramps when I was a youngster, and I didn't care for them, either. But the plastic ones have been good for me.Maybe I'm just leery of ramps because the ones my dad had were a bit steep (so they didn't work for my car at the time anyway) but when you'd go up you're REALLY going up, and then you'd get to the top and lurch forward. They were metal and instead of flat on top they had a concave spot to help "hold" the tire in place I guess, which I'm sure greatly contributed to the lurch. Rather unnerving, and I just didn't like it.
More like 20-buh-zillion pounds!Mine have a weight rating of like 20,000lbs. I also made them myself with 2x10"s.
based on some experts, regular one is good enough for normal driving, Wix XP is for towing task.I know I’m paying a little more, $15.99, but I have been using WIX XP oil filter (57356XP). It’s not the regular WIX. It’s the XP. Anyone using this one and have any opinion?
