With 15400-PLM-A01 no longer available, what is your favorite oil filter? I have heard a lot of positive things about FRAM XG7317 Ultra Synthetic. Amazon sells them for $7. Is there any other oil filter on the market than offers a better value?
Fram ultraI know I’m paying a little more, $15.99, but I have been using WIX XP oil filter (57356XP). It’s not the regular WIX. It’s the XP. Anyone using this one and have any opinion?
Terrible idea for towing.based on some experts, regular one is good enough for normal driving, Wix XP is for towing task.
Experts? Who? I'd say you probably have enough information as a regular Joe Consumer (like me) to know that you should just use the best filter you can get at a price you agree with, and use that for any task. I do that, no matter if it's just me in the van, or 2,000 lbs. on the hitch and a few hundred pounds of tools in the cabin.based on some experts, regular one is good enough for normal driving, Wix XP is for towing task.
here is the linkExperts? Who? I'd say you probably have enough information as a regular Joe Consumer (like me) to know that you should just use the best filter you can get at a price you agree with, and use that for any task. I do that, no matter if it's just me in the van, or 2,000 lbs. on the hitch and a few hundred pounds of tools in the cabin.
Yup. The absolute last thing you’d want towing or hard under load would be less filtration allowing particles and larger particles to circulate.I don't really choose a filter based on "am I just driving?" versus "am I towing?"
Surely your oil supports the engine. High loads, severe service: good synthetic oil all the way.
On that note, the filter supports the oil. The oil, no matter which you use, can't do its job as well as it could if wear particles and contaminants produced by the operating engine are not captured by the filter and are thus allowed to keep moving through the lubrication system.
I think we've all interacted with mechanics, and some of us with engineers, who've seen first-hand the effects of "not enough filtration."
Is there such a thing as "too much filtration"? Maybe, but if I'm not using a bypass system added to the engine's regular full-flow filter, it's hard to see ever using a not-so-great filter for general use and then a better one for severe service (like towing.)
My take (like most people, I'm sure): get the best filter you can (cost versus benefit here) and keep using that, and change oil and filter regularly.
Nice comparisons. BTW, I think you meant to type Filtech A01 filters. I will be sad when my inventory of A01 filters run out in a few years.FRAM Ultra is best for filtration. It's not best for flow. K&N is best for flow while maintaining good filtration. FRAM racing is probably best for flow.
So it depends on what you want/need. If you operate at higher RPM for extended periods towing up hill, flow will be more important (to keep bearings cool and avoid pressure drop).
Personally I use FRAM Ultra cause we don't tow or race up grades above 3500rpm.
BTW: Honda A02 filter is made by FRAM/Honeywell and is a shitty Fram basic orange inside with cardboard end caps. The only thing Honda spec'd as an upgrade over the cheap Fram orange was a few extra pleats and a silicone drain back valve. Not worth the $7 when a Fram Ultra is $1 more and available at every Walmart next to the 5qt jugs of mobil1.
A01 left, A02 center, FRAM orange right. See the current A02 is a cardboard piece of junk! I miss the old Filters A01 filters. Kept one in my collectables stash lol.
What is your basis for saying the Fram Ultras don’t have “good flow”? And then what standardized test are you basing this upon?FRAM Ultra is best for filtration. It's not best for flow. K&N is best for flow while maintaining good filtration. FRAM racing is probably best for flow.
I'm glad I'm not the only one who is thinking this.What is your basis for saying the Fram Ultras don’t have “good flow”? And then what standardized test are you basing this upon?
This relates to an oil filter discussion how?Should I try AT-205 in the crankcase as many forum guru suggested? 06 EXL with 300k km .
In past 2 oil changes, I noticed oily moist on my oil pan, engine low body, and even on Tranny housing, all the way to Tranny side right above the Neutral safety switch area.
Basically it was slow leak, not noticeable from oil stick level, but for 5K miles(10k Km) OCI time frame, i need to top off once, probably 300 ml or more, so it won't be lower to the min. I had muzzled VCM 2 years ago, so oil burning shouldn't be this much. from top, the upper portion of the engine bay is quite dry, Valve gasket is no leaking. I had checked Transmission level quite often, no drop. Power Steering level did drop a little along the time, but after remove the bumper, there is no visual PS fluid leak along the pipe and joints. so my concern is there is a slow oil leak developing somewhere. and it get worse now, recently i had noticed some oily marks on the driveway, not puddle though, at driver side front left just under battery tray area. is this a syptom of infamous Real Main Seal leaking?
Ummm me?Who da f is putting the van on jackstands just to change the oil? Bruh...
Pretty much.I'm glad I'm not the only one who is thinking this.
My thinking, correct me if my reasoning is wrong: if all of the tested filters "flow enough" under all operating RPM's to deliver oil in sufficient pressure and volume to our street engines, then these measurements of flow resistance aren't as important as "what the filter does for us" (namely, capture and retain contaminants and generated wear particles.)
I think I'm on the right track here?
well, as we were discussing oil change, that leak concern from my oil change observation popped up, so I asked the question BTWThis relates to an oil filter discussion how?
So. I do have an explanation. Storing ramps needs space and my garage is cramped with a lot of other crap but we keep the space for both cars to be parked inside is the primary driver./squint
Step into my office, please.
Completely agree with that!Of coarse loading your oil with spoonfuls of aluminum powder till all the filters max out is hardly an example what really happens inside an engine. Just an interesting demo what "could" happen when you let your oil get way too dirty.
