I was driving today and the van all of a sudden died on me and stalled. I had a chance to pull into the emergency divider and wasnt able to find any significant sign of issues. All fuses were good and no leaks. I also had 3/4 of fuel left. No CEL neither. I tried to start again and nothing, crank-crank-crank and for a good 10 mins and nothing. There was heavy traffic so was really unable to hear the fuel pump priming. After about 5 minutes, It started again but had hesitation and then shut off again and the crank-crank-crank scenario continued. 5 minutes after that, the van started as if nothing had ever happen. Decided to turn around and drive it back home and was able to make it. Turned the van off and turned it back on a few times and no issues.
I was told by the prev owner that it had happen to him months ago and he decided to park it until he sold it to me but almost 500 miles into buying it and it just happens to me. The van was lacking maintenance and went thru a full repair session with me to make it roadworthy again (full front suspension components, cleaned TB and passages of carbon, Denso plugs, OEM 02 sensors, PCV valve, power steering O rings, lines and flush). After all this the van was running like new and thought perhaps I would not experience that issue he had, I was wrong.
Could this point to the infamous Main Relay solder points damage or ignition switch failure? I also read that there was a recall on this but checked Honda’s site and my van has no pending recalls or TSB’s.
Anyone, else experience this lately?
