21 - 39 of 39 Posts
Very similar to how an AC system is filled. You suck all the air out of it, then let the system suck the coolant back in. It makes it easy to get all the air out of the system. I can start up an Ody and have heat in the front and rear as soon as it warms up. No air bubbles.
This is the one I have. This isn't a great video and I do it a bit different than this guy but you get the idea. I dump a couple gallons of coolant into a bucket and then let it suck the air out of the fill hose while it's vacuuming. Then let it sit to make sure it holds a vacuum, then let it fill. When it's done, remove the hoses, top off the radiator and expansion tank, put the cap on and you're done.
Guys, I just got one of these.
Finally, got out of the stone age, and I'm done with coolant burbling out of the radiator fill neck onto the car's frame, the garage floor, or onto me.
This wonderful device fits every Japanese car in my garage and driveway. The Odyssey, Accords, Civic, Corolla, Altima, and TL Type S.
Everything fits into the funnel, so easy to store in a garage cabinet and keep it all together.
What took so long for Lisle to invent this?
My 2 year schedule is almost up again and I have been wanting to get something like this. LOL, Man, I don't even bother warming up the engine with the cap off (to avoid coolant splash on me)I just fill it up. Put the cap on. Warm the engine , turn it off, let it cool, and then add some more coolant. Then just keep parking the car on our inclined driveway - nose up -and monitor the coolant level for a week. It usually stays level after a few days. Never had issues with trapped air ever. Never done coolant flash ever since I owned a car also. I just drain and fill often.
A drain and fill often is all that's needed on these Honda's. You can, however, get air bubbles especially in the rear heat. Been there done that. There is a long procedure in the service manual for making sure all the air is out. The vacuum fill gets all that air out without going through that procedure.
Hmmmm .... if acquring newer vehicles force me into getting one, I will. For now, this Lisle funnel and a six-pack (for consumption while waiting for engine to warm up) is fine by me, and still way ahead of the way I was doing it.
Speaking of the stone age, I am going to just sell the Altima. Don't get me wrong, it drives great. The 3.5L four-cam V6 really has good, smooth power delivery everywhere. The handling under power is as close to neutral as I want with a FWD car, with controllable steering even with tires starting to break loose. Brakes are fabulous on OEM pads & rotors. What's not to like?
The engine bay. It's tight. Way too tight. I need multiple shoe horns and timber wedges just to change the blamed alternator. I'm speaking figuratively, of course. The bumper and radiator have to come off the vehicle to remove/replace the alternator. Changing the D2R HID capsules requires bumper off, headlights removed. I'm done with it, finished.
Working on a 3.5L V6 Accord is loads easier in every way. My wife's 2012 EX-L is nowhere near as sporty in any dimension (acceleration, braking, cornering, and combinations thereof) compared to the Nissan, but tonight my banged-up hands have told me it's time to let it go...
...of course, after I top up the coolant (the last step in this difficult job).
You too. lol. I just replaced my 2004 Murano alternator less than a month ago. Its basically the same engine. I did not have to remove the radiator or bumper but the cooling fans and batt tray has to come off. And the idler pulley. This car with 100K less miles has more issues than the older odyssey. My wife has been pushing me to look for a new high car according to her. meaning not a sedan.
Yes, shop air is needed. There are lots of cars out there that are prone to air entrapment during coolant filling. I don't expect everyone to delve into the vacuum fill method but thought I'd share that it works so good, and so reliably, that I use it on every vehicle I fill. The Astro kit comes with a pressure tester, and all the adapters needed for almost any car. The vacuum fill tool was included but I didn't use it when I first got it. After the first time I decided to try it I was sold.
OT: I highly recommend getting rid of those Nissans before the transmission shreds its belt and you have to drop $5k for a factory reman on a car worth only $3k. Seen that too many times.
As soon as this job is done, the Nissan goes up on Craigslist and Facebook Marketplace. Love the way it drives, just cannot stand these other included "features by Nissan" that kill reliability and make it a bear to work on.
Really do like getting new tools, but still working on changing my "one car garage" back into the "two car garage" that it used to be.
Tell me about it. My Rogue's tranny bit the dust at 78k.. :( (My '06 Ody with "terrible/weak" transmission is still going strong at 173k)
Fortunately, I got the Rogue as "certified pre-owned" and it had 2 more weeks to go before extended 8 yr 100k mile powertrain warranty to expire so Nissan covered the $4800 cost minus $50 deductible.
I DOUBT it will last to where my 06 ody is now. That said, nothing else broke on Rogue so far (knock on wood) though. (At 80k or so on Ody, PS pump was replaced, motor mounts (both front and back) were replaced, Navi screen has been replaced)
EDIT (this para added): hpark21, don't sell your 05-06 Ody, ever. They never go up for sale on Craigslist in my area, because everybody owning one keeps on trucking. If one comes up for sale, it is usually approaching 250,000 miles on the odometer, and still truckin'. Honda not only fixed all of the H5-type transmission 3rd gear oiling issues, they gave it a end-user replaceable cartridge filter (not the canister with what appears to be a smaller filter element). These are the only Odys ever, to my knowledge, with that setup.
Back to the funnel. Going to use the Lisle funnel, either tonight or tomorrow. It may not be the latest and greatest, but for the price (the funnel, and the cost of those two beers I'll drink while using it), it's a gem.
Finally got the Altima's alternator mounting bolt in. It has to be carefully maneuvered behind the pre-cat on the front bank of cylinders. No idea which sadist at Nissan designed this. Had to remove the O2 sensor on that pre-cat to get enough room. Lot of sharp edges in there. I'm a little bloody right now, but at least fairly "normal" work is all that is left: re-install O2 sensor and harness, re-install radiator, then the dual fan assembly, connect radiator and ATF in-tank cooler hoses, finish fabricating a custom additional 4 AWG transmission case-to-chassis ground and install it, install the bumper cover, re-mount the right front wheel [had to remove it to gain access to the $%#@^&*!!! alternator], install serp belt and tensioner, re-install splash guards, re-install bumper cover and grill.
All that for one stinkin' alternator.
I remember once looking at an AC Delco alternator on a Chevy truck and thinking, "Wow, that'd be easy to change." Not that I'd ever have to change one except maybe once every quarter million miles, because AC Delco makes really good alternators. People retrofit them to older Honda Gold Wings, they're the alternator chassis of choice for custom marine applications, etc.
I know Denso makes great alternators ... but this Nissan electrical system is brittle. It seems the Nissan forums are full of people adding grounds all over the place to help ensure the alternator is actually allowed to deliver its power where needed ... it can't do it if "the return path" is constricted.
The most pleasurable aspect of this Nissan Altima 3.5 SE alternator replacement job will be using that Lisle funnel!
Reactions: hpark21
Yeah, I needed to remove all the front CAT heat shields just to be able to reach for that thru bolt for the top mounting of the alternator on mine. Pain in the butt. Good thing we are handy. lol.
So true, Nissan Jatco CVT is the worse of all. I hear Toyota CVT are the least problematic, while Honda CVT has not much data yet but seems much better than Nissan. My 04 Murano is one of the pioneer bigger CVT installed in a crossover and somehow does not suffer from fluid issues or overheating like the smaller cvts in Nissans line up. Valve body issues, stepper motor and bearing are the common problems. Whats worse is repair is basically impossible due to no replacement parts availability and instructions. Its always complete replacement. I hear reason for this is, assembling back the cvt requires a special expensive tool to be done properly. Otherwise something will be off. Like the belts alignment I suppose. Just speculation. I dunno, but its the reason I am avoiding CVTs for now. However, almost all smaller engine cars now has it and its harder to find one without it. NO escaping from it. lol. I really like how the CVT seamlessly move when doing long trips on cruise control. No gear hunting. Engine braking is great as well on my Murano. But gas mileage is a joke. 18 city/22-24 high way. Anyway, I'm on the hunt for a replacement. No rush though.
I'm lucky to the have the 5-speed Aisin transmission. Just unlucky with the rest of the vehicle.
Me, too...trying to stay away from the inevitability of the CVT in successive small car purchases.
I've got to get my butt in gear. Almost done, have to install battery, add coolant, fire it up, crack open beers, and use my Lisle funnel. :cool:
P.S. hpark21, just saw what looks like an '06 for sale with over 300,000 miles on it (grill peculiar to 05-07, 7-spoke wheel design only on 05-06). I tell ya', those 05-06 Odys are used car sleepers. Last forever, can get one for a good price...IF you can find one.
owns 2006 Honda Odyssey EX
One of the available optional wheels was a handsome looking 16" diameter 7-spoke design that was specific to the 05-06 model years:
162147
The rest of the wheel designs available in 2005 were available on all years through 2010.
BTW, the funnel was just what I needed. Nissan running again, makes burping the cooling system a mess-free job.
OF.
OF.
Huh. This is certainly the first time I've seen or heard of these wheels. I don't see them listed on Bernardi either. I know my 06 has the standard 5 double-spoke wheels. I was only aware of these wheels for the 3rd gen:
05-10 LX steel + hubcaps
05-07 EX/EX-L 5 double-spoke wheels
05-09 Touring w/ PAX (optional in 08-09) 10 spoke wheels
08-10 EX/EX-L 9 spoke wheels
08-10 Touring w/o PAX 5 spoke wheels (I think these would look the best on an 05-07 Ody)
I saw them on originalwheels.com when I was "Odyssey shopping" for an 05-10 Odyssey. When I first saw them, I thought they were from another Honda or Acura product. It seems they skipped a year with that design (2007).
Back to funnel topic:
Adapters on the Lisle product provided for everything. So far, it seems the same adapter for the Nissan fits our Hondas & Acura. Haven't checked the Toyota.
If you don't have shop air, the Lisle funnel is a good purchase. It was for me, even though I have a fairly stout upright compressor. A vacuum system will be in my future if a newer car purchase requires it, but for now this should serve me for the next several years.
OF, I used the funnel on our Avalon and Camry. Saved lots of time, effort. While back remember all that coolant green to blue stuff. Had to do that on ody again and avalon (green to red). Also on drain/fills. Already got back money worth on that funnel.
21 - 39 of 39 Posts
