1 - 20 of 68 Posts
EE4Life
· Super Moderator
Reactions: Richard76
The eStore link opens in a new window. minimize it. NOW try the pdf link...Ah HA.
Follow the steps in the first post.
Step 1: Open eStore link. Don't close that window, just minimize it.
Step 2: Now click on that PDF link. It should now open.
If you want to perform the burdensome task of saving EVERY LINK on EVERY PAGE to the same folder,
you can have a fully functioning copy for yourself. I've copied all the main links, but not all the photos and connector diagrams.
Hi. Only getting content page on the PDF with clickable buttons, but nothing happens. I've tried all combinations of opening new tabs with the estore. Is this PDF still active? Is there another way to access it? I'm having massive electrical problems. Thanks.
I was trying to open the links at the same time you were. Same result, nothing opens.
Discussion starter · #10 ·
What setup are you both running? I am using a Windows PC with IE9 and it works fine.
I was running Windows with Chrome. Worked fine when I switched to IE. Thanks!!!! The diagrams helped me narrow down my problem and find the solution. An almost inperceptable break in a 7.5amp fuse that was causing about 8 things not to function correctly. A mechanic friend and I had checked this exact fuse at least twice before. Thanks again!!!!!!!
Same here. The biggest problem now is the links don't work in the saved PDF. You still have to go to the live page to get the various pictures and schematics. This is a huge amount of info!! I'm going to put a link to this page in the folder with the PDF's I've saved.
You may have coins in the CD player - seriously.
Or the accessory socket has fallen out of its position and shorting.
1 - 20 of 68 Posts
